purge vavle and iavc mix up
Fri Apr 12, 2013 4:07 pm
by madhatchride
ok so i made the mistake of plugging the purge valve side to the iavc and vice versa.i called a shop and they said if this happend that it would burn something out in the ecu. well what would this effect does anyone know what would happen? the car isnt 100 % done so i have nothing to go by on if it runs better or worse
Sat Apr 13, 2013 1:35 am
by rustyrex
the only thing that will happen is the idle will jump up and down real fast like the vacuum line for the brake master cylinder is unpluged. i did this exact same thing when i did my swap, those 2 harness plugs are exactly alike. just make sure you switch them before you go to drive it.
Mon Apr 15, 2013 2:53 pm
by madhatchride
well see the problem is i didnt know i didnt catch they were switched till a a month after ive been testing it and driving it a lil will it cause any problems other wise like for example the car will not hit red line at all n doesnt seem to run like a b18 should
Mon Apr 15, 2013 4:31 pm
by rustyrex
Of course it is not going to run correctly. The iac and purge valve are not working. It take 10 seconds to swap plugs. I'm really surprised its driveable. My cars idle was jumping so bad when I did that it kept stalling when I tried to pull out of my driveway.
Tue Apr 16, 2013 3:24 am
by madhatchride
well even after i switched them i still have the slight retarded jump issue and they said it would burn a big hole in my ecu
Tue Apr 16, 2013 3:25 am
by madhatchride
not a big hole but would burn the main board
Tue Apr 16, 2013 3:38 am
by TrailerTrash
hook them both up and start the car. if the car runs like shit and the check engine light is on then they are backwards.
Tue Apr 16, 2013 3:44 am
by madhatchride
i know there right now im sure it idles ok and i have no cel for my iavc but i was told that having them switched for a period of time can burn your ecu out and btw i just got done reading your whole coupe build forum
nice
Tue Apr 16, 2013 4:44 am
by JUICE
I'd say its probably fine, people confuse them all the time and have no problems once they fix it. I'm actually running my EBC boost solenoid off the wires that used to go to the purge valve.
