ECU, Wiring, Sensors
By Ej2-B16a
#31706 1. Take out your jumper cables.
It's a good idea to buy a set of jumper cables and keep them in the trunk compartment. If you don't have jumper cables, you'll have to find a Good Samaritan who not only is willing to assist you but has jumper cables as well.
2. Place both cars in Park or Neutral, with their ignitions shut off and their emergency brakes on.
3. Remove the caps from both batteries (unless they're sealed).
Batteries produce explosive hydrogen gas, and a spark could set it off. If the caps are open, you can avoid such an explosion. (Sealed batteries have safety valves.)
4. Connect the cables.
The positive cable has red clips at either end, and the negative cable has black clips. It's important to attach them in the proper order:
1. First, attach one of the red clips to the positive terminal of your battery (it has "POS" or "+" on it, or it's bigger than the negative terminal).
2. Attach the other red clip to the positive terminal of the GS's car.
3. Attach one of the black clips to the negative terminal on the GS's battery.
4. Attach the last black clip to an unpainted metal surface on your car that isn't near the carburetor (if your car has one) or battery.
5. Try to start your vehicle.
If it won't start, make sure that the cables are properly connected and have the GS run his or her engine for five minutes. Then try to start your car again. If it still won't start, your battery may be beyond help.
6. Disconnect the cables, thank the Good Samaritan, and resume your life.
Don't shut off your engine; drive around for a while to recharge your battery.
:thumb:
