- Mon Nov 19, 2007 4:35 am
#30441
This is not about my EG, but my EK... Maybe someone will still have some advice:
the alternator on my 96 hx seized up while the car sat for a few months. Bought a new used one from ebay "works excellent" seller had 100% feedback. it came w/o a pulley as described.
So I pulled my old one out, put the pulley on the new one, and then noticed that the douche sent me one with a round connector (92-95) not 96-00 like the auction said.
rather than mess with returns, I had an old chopped up OBD1 engine harness with the round plug, so I cut it off and made a conversion harness to go from my civic's OBD2 plug to the OBD1 alternator.
I have a chilton's for 92-95, and a chiltons and haynes manual for 96-00. After studying all the schematics,:
OBD1:
Black/Yel = fuse box, ignition
White/Blue = fuse box, indicator light, ignition
White/Yel = ecu = A21 pin
Blue = ecu, C5 pin
OBD2:
Black/Yel = fuse box, integrated control unit
White/Blue = fuse box, hot on start
White/Green = ecu, Alt Output Sig
White/Red = ecu, Alt Fr Sig
OBD1 .............. OBD2
Black/Yel.......... Black/Yel
White/Blue........ White/Blue
White/Yel.......... White/Green
Blue.................White/Red
So I plug it in, and hook up the main thick white wire too. Now my entire car dims on/off constantly, dome light, cluster, headlights... if I drive on the road at night, it almost looks like I am flashing my headlights at people But the car seems to run fine.
I measured my 96 pulley with a 92-95 pulley to be sure my 96 wasn't bigger diameter, acting as an underdrive pulley... but both were 2.75" diameter.
Question, do the OBD2 alternators have different AMP rating than OBD1?
What else could cause this to happen?
OBD1:
Blue = ecu, C5 pin
OBD2:
