- Mon Sep 06, 2010 9:43 pm
#212524
ok 2 days ago i was at work and used my car to go get some parts. came back and it was all good. then about 10 min later i went to get some food and as soon as my car turned on the cluster gages stoped working, and my clock. raidio and stuff worked. tryed my blinkers and nothing. hazerds worked. the back light on the cluster workers and the battery light will light then shut off like normal,. but the engine light and normall start lights dont shine on. brake light and stuff worked but no reverse lights.
thats what my proablem is. sofar i have checked all fuses, plugs and everything. all was good. what should i check next.. thanks guys...
i have almost lost all my respect for this damn car. im on the verg of tasking it off a cliff. and im very seriouse. if i can fix it by the end of the month the car is proly going away. so as my last and final hope can someone please help. and dont fucking say "checxk your fuses" cause i fucking have like 40 times. and there is no fucking cel codes. is it posibble tthe hazard switch was no good???? what all goes to the dash. befor i smashed the hazard switch i pluged the clock switch plug int the hazard switch. no its not the same size but my gauges all started working and so did revers light. and the key in the ignition ding stoped. wtf?????? can anyone help? anyone pleasssssssssssssssssssssssssssssssssse.......
