Page 1 of 2
d15b
PostPosted: Wed Jan 06, 2010 3:39 am
by twc2010
i have a obd1 d15b jdm vtec motor. it currently has a d16 intake. it also has the p28 ecu. is that ecu okay or do i need to get a p08.
PostPosted: Wed Jan 06, 2010 3:42 am
by d-mon
p28 should be fine.
does your vtec solenoid have the oil pressure sensor(green)?
PostPosted: Wed Jan 06, 2010 3:48 am
by twc2010
it just has one wire coming out of it. i think it is green/yellow.
PostPosted: Wed Jan 06, 2010 3:58 am
by d-mon
not the wire, the plastic connector.
its behind the distributor plugs.
PostPosted: Wed Jan 06, 2010 4:02 am
by TrailerTrash
I'm running my D15B with a p28 with no problems.
PostPosted: Wed Jan 06, 2010 4:14 am
by d-mon
TrailerTrash wrote:I'm running my D15B with a p28 with no problems.
p28 will want the oil pres switch. if you have one it will be fine.
if not i recommend getting a vtec solenoid that has one.
this one does not have the green 'thingie':
PostPosted: Wed Jan 06, 2010 1:06 pm
by twc2010
i'll try to take a picture of it today
PostPosted: Wed Jan 06, 2010 3:56 pm
by d-mon
this shows it better:
PostPosted: Wed Jan 06, 2010 7:23 pm
by twc2010
do all vtecs have to have that pressure switch.
PostPosted: Thu Jan 07, 2010 3:17 pm
by d-mon
twc2010 wrote:do all vtecs have to have that pressure switch.
no. i posted a pic of one that doesn't, two posts up.
its a green connector, hard to miss.
the only other one is on the power steering rack.
d15b vtecs have one of 2 solenoids. with oil pres switch or without.
which one do you have? (y8's are different, btw)
PostPosted: Thu Jan 07, 2010 3:33 pm
Which motors had the vtec solenoid without the pressure switch?
PostPosted: Thu Jan 07, 2010 6:45 pm
by twc2010
mine does have a switch
PostPosted: Thu Jan 07, 2010 10:30 pm
by d-mon
teal_dx wrote:Which motors had the vtec solenoid without the pressure switch?
not sure which.
i have gotten d15b's that came with solenoids with and without the presure switch. that is why i am asking.
twc2010 wrote:mine does have a switch
then you are good for p28
PostPosted: Sun Jan 10, 2010 4:18 am
by twc2010
i'm an idiot. i posted saying it has the switch. i meant to say it didn't. plus where exactly would the harness be for checking codes. the car has a vtec controller. is the harness inline with the wires on the ecu or connected to the ecu in some other way.
PostPosted: Mon Jan 11, 2010 6:00 pm
by d-mon
