ECU, Wiring, Sensors
By will91DA
#130101 Whats going on I Justs got a sedan and I cant figure out why my running lights arent working.. Does anyone out there happen to know why this might be or what may cause it??? HELP ME OUT
:eh:
By 3kkl3sia
#130102 You probably don't have them. Unless you got one of the one's with them, but i have yet to see one with them that the owner didn't do himself.
By will91DA
#130105 reason i say that is because the only lights that work are the lights on the back of the car... and the corner lights on the front only control the turning signals
By egsedanguy
#130106 well first are cars are stock with the corner lights and tail lights act as running lights. are you talking about the side markers? cause if so mabey you need to check to see if ther even wired up or have bulbs.... if you sayen your cornerlights dont come on then check for a fuse, connection.
By 3kkl3sia
#130109
egsedanguy wrote:well first are cars are stock with the corner lights and tail lights act as running lights. are you talking about the side markers? cause if so mabey you need to check to see if ther even wired up or have bulbs.... if you sayen your cornerlights dont come on then check for a fuse, connection.
i misunderstood what you ment, i thought by running lights you ment the really dim headlights...haha
By will91DA
#130110 Yeah sorry.. im talking about the running lights on the corner lights and on the rear of the car.. When i turn on the headlights those lights should come on right?
Cuz they dont.. and I put a test light to the fuses under the dash but i cant figure out which one it is cuz theres nothing telling me and theres a couple of fuses under there that arent working so i dont know what it could be
By egsedanguy
#130112 yes they should come on. look here http://civic-eg.com/viewtopic.php?t=2089
check all the fuses. under hood and under dash. if the fuse is blown then thats the one. if you have to pull every fuse under the dash 1 at a time.
By will91DA
#130116
egsedanguy wrote:should be #19 10amp fuse for parking lights :thumb:
dude thanx a lot for the help...
By will91DA
#130158 yeah man... It worked....lol I couldnt figure out which one it was for the life of me cuz i didnt have the diagram...
#130180 yo milk-dud
haha
so you finally got ur lights workin :thumb:
now you need to get rid of those black corners
for some ambers or clears 8)
