ECU, Wiring, Sensors
By mistergou
#128491 Hey guys was wondering if the Hondata s300 will be good enough for tuning ITBs or if I should spend the few extra 100 of dollars an get the AEM EMS??
any input would be great
By flyinryan122
#128499 Go with the HONDATA s300. To properly do AEM on any B/D/K series it costs about 3200 dollars. Hondata will eaisly do the job
#129077 $3200?!! Where do you get that figure?? It costs about $100-200 an hour for tuning, no matter what system you have. And the EMS can be tuned in about an hour although with ITB's I'd plan for about 3.
I don't think that you can even get ITB's streetable with a piggyback. You'll want to run Alpha-N with MAP feedback. The EMS wont even bat an eye at this.
AEM EMS with built-in wideband O2 is going for $1300 right now. That's probably less than your ITB setup is costing you.
By flyinryan122
#129080 Ummm that estimate is from Cortney Green. remember? the same guy you had that big argument about this exact question over on utahhondas.... the same guy that has built every single fast honda in utah, including four of the fastest hondas in sport front wheel drive that are all out of utah. If you'd like i can copy and paste everything that was said? or post a link....
By mistergou
#129132
suspendedHatch wrote:$3200?!! Where do you get that figure?? It costs about $100-200 an hour for tuning, no matter what system you have. And the EMS can be tuned in about an hour although with ITB's I'd plan for about 3.
thanks for the advice suspendedhatch, this was the answer I was looking for, I'll be saving up a lil extra an prob get the AEM.
An no my itb setup did not cost that much, it's homemade setup
