ECU, Wiring, Sensors
By asianrob
#124782 when i got my 4door the power locks did not work.. looked at the fuses. they where good.. changed out the control unit and still nothing.. and i changed out the switch still nothing...
any ideas of where to look next?...
thanks in advanced
By yashep
#124788 It's there anyway you could trace the wire from the fuse box all the way to the door? maybe the wires are cut or a ground cable is loose :?
By asianrob
#124814 i could try that lol.... i'mm a see if i can get a diagram and go from there
By dawg316
#124846 test light my friend. check before and after every switch/ actuator. probably a door lock actuator
By asianrob
#124869
dawg316 wrote:test light my friend. check before and after every switch/ actuator. probably a door lock actuator
i got two known good working ones switches :(
By asianrob
#124873
eg_turbo_hatch wrote:did you check the relay in the fuse box
not yet. i'll take a look at that tomorrow.
