- Tue Mar 12, 2013 6:09 am
#328416
Ej1. Starting off, it started doing this after i put in my subs and hooked up a new head unit. After work the battery was dead. Jumped it and came all the way home (not playing any music) with no problem. Next day, tried starting and all lights were very dim and wont start so i charged up the battery took off the head unit, amp, subs and all wires that i connected. its been working for 2 days total now but the battery light started to blink from time to time. I notice today when coming from home that when it DID come on it seems like the front lights came on even brighter than usual (like it was switched to high beams) any thoughs.
Also i remember u can check the altonator by removing either positive or negative terminal n if the car runs then its good so which was it (positive or negative) dnt have a volt meter so tryin to figure out before buyin one thanks guys
ive always done that to test the alternator. i unhook the battery cable and turn everything on thats electrical in the car. radio, lights, heater, ect. if the car runs the alternator is fine as far as im concerned.
