- Wed Nov 28, 2007 4:26 pm
#31669
I've seen them before, but can't think of what they are called... and I need to find some.
They are used when you want to connect 2 separate wires. The connector is a little plastic square that has a little cover that opens up. Then you put the 2 wires into the slots and close the cover. Then there is a small metal piece that is on the cover. You squeeze that with pliers and it pierces through the insulation of both wires, making an electrical connection between the two.
anybody know
anybody know
My 1992 SOHC Turbo Hatch
