Differences in H series
USDM H22 open deck block
USDM H23 closed deck block
JDM H22a closed deck block
so i'd say closed deck = boost!!
The following is a fine example of a closed-deck block. The cylinder bore is mated right to the surface of the block which gives it incredible stiffness and resistance to warping or cracking. These engines are created using the "sand-cast" or "lost-foam" methods. Both aren't terribly expensive methods of casting, but they'r emuch less accurate than using the die-cast method. This is why all Subaru engines currently use the die-cast, open-deck design.
teal_dx wrote:The following is a fine example of a closed-deck block. The cylinder bore is mated right to the surface of the block which gives it incredible stiffness and resistance to warping or cracking. These engines are created using the "sand-cast" or "lost-foam" methods. Both aren't terribly expensive methods of casting, but they'r emuch less accurate than using the die-cast method. This is why all Subaru engines currently use the die-cast, open-deck design.
closed deck:
open deck:
