- Thu Sep 09, 2010 1:07 am
#212828
to make a long story short, i installed some lowering springs/shocks on all corners. once we were done, fired the car up, and these three CEL lights came on. knock sensor, ELD code and the VTEC code. ELD code has been there for awhile in the background. I haven't really found much info on what it does or how to remedy the CEL, it never stays on so i don't worry about it.
i know VTEC worked before we changed the springs so i don't know why the CEL came one. VTEC has always worked. I've tried clearing the codes, in the both ways that i know how, pulling the backup fuse and the ECU fuse. codes still came back. In the earlier days when this problem came up, when i turned off the car and turned it back on, the CEL would go away. recently it now stays on. i have replaced the knock sensor, and the wiring seems ok. i know i don't have an engine knock (90%) had a couple people listen and we don't hear any distinct knocking.
is it possible that my timing might cause this issue or if there all related? i hate driving with a CEL. what other things should i check?
Honda: making pizza delivery profitable since 1977.
