- Thu Jul 08, 2010 12:43 am
#203601
sweet thanks man. hopefully i'll be doing this in the coming months...
- Fri Jul 09, 2010 3:22 am
#203768
well im thinking bout selling my stuff so if ur interested let me know....send me a pm with digits
- Sat Jan 15, 2011 3:20 am
#233358
H2D FTW!!!
pure awesomeness..
So in order to fit. u will retain the OEM tranny and Rear mount and u need a custom Driver side mount!! Pure awesomeness!!! HaLeLuYa!!!
Team XXX Racing/WGHonda
- Mon Jan 17, 2011 8:17 pm
#233851
So it sits in there pretty nicely.. Now i see it's very close to the Driver shock tower. Did u have to cut anyhting to make room for it to fit at all? and about the driver mount, it looks tight there. any modification to the Driver frame rail there?. Also. did you have to space the hood or cut the the support brackets on the under side of the hood at all?
mooze wrote:yep....heres a pic just to show.....excuse the messy wires and such
and this is how it sits
- Mon Jan 17, 2011 8:36 pm
#233854
yeah real close to tower....i shaved it a little so the vc would clear tho u could just bang it a little...in the video u can see where i cut the frame (with torch) to assure i had belt clearance ....hood is spaced with washers and longer bolts and support is cut out
- Wed Mar 09, 2011 9:46 pm
#243204
Mooze.
What axles did u use for your set up? OEM? or custom length?
If u did use ur OEM ones how well did they fit, did they bend a lil in an awkward way when installed?
- Fri Mar 11, 2011 5:40 am
#243427
y cant i see the vid? it's asking me for a password..
mooze wrote:here is a vid 1st gear pull. and i have VTEC solenoid disconnected. so guess what no VTEC. well i didnt floor it as i had to look for deers and such.i came into a line of deers when i slowed down. stock tranny from d15b7
- Fri Mar 11, 2011 8:37 pm
#243509
oem length...the tranny is going to sit it stock position....all mounts will bolt right up...it will be as though a dseries is still in the bay
EG6b20R wrote:Mooze.
- Fri Mar 11, 2011 9:00 pm
#243512
ok cool.. Im thinkin like the Replacement mounts for B and D series interact. just wondering if H2B mounts would have the same concept?.
Just curious.. lol
Just curious.. lol
but this time ill walk through the complete process
