- Tue Apr 24, 2007 6:35 pm
#6497
(For anyone unfamiliar with this setup, the idea is to create vacuum to vent the crank case and valve cover. When done correctly, a 45? slash cut tube placed in the exhaust will create vacuum by the Bernoulli Effect )
I'm looking into this setup and having a hard time finding good info on it...
I've read about it but want to be sure I have all the details right before I attempt... Here's a drawing:
And Here's what I've read:
- the metal "slash" tube going into the exhaust should go straight into the down pipe at a 90 degree angle.
- the slash should be at a 45 degree angle away from the exhaust flow.
I'm unsure of how far the tube should go into the down pipe?
What do you guys think about this setup?
+1
