- Tue Aug 28, 2007 8:00 pm
#21367
***from our local forum (the images posted came from a friend)
Vtec engine
Materials needed:
1. LED of your choice 1 pc
2. Gauge 22 or thinner wire 4 meters
3. Electrical tape
4. 1 kilo ohm resistor
Procedure:
Mount the LED where you think it is most visible. At first I placed it in the steering clumn but I transferred it on the left side of the dashboard..
I bought a vanity light (or led light will do) in a local hardware shop. (Bright blue LED is my sample)
Connect the negative pin to the ground. Under the dash there are may screws where you can tap to get a negative ground.
Connect the positive pin to a resistor then solder the resistor to a wire.
Now there are two ways in order to tap on to the vtec line.
You can tap directly to the ECU. For ODB2, its the B13 pin of the ECU. for other systems just refer to the shop manual.
Or you can do it the easy way. Tap directly to the vtec solenoid socket! I just tapped it so no wires were cut or stripped. All you have to do is route the wire from the LED to the engine...
i mean rob you even said its so barely noticeable how do you know its actually working?
am i just being a nooblet and assuming the ecu would still throw a "signal" to start the vtec if it wasnt hooked up?
