Give us your D-series!
Postby suspendedHatch » Wed Nov 21, 2007 5:33 pm
I believe the (OBD2) D15B to be the best D-series motor ever created (for a street car*).
The first stage is 12 valve mode. One of the intake valves is almost all the way closed. This increases air velocity into the combustion chamber at low RPM and also swirls the incoming air in order to burn all the fuel. This avoids the compromises that are made at low RPM on a normal motor, resulting in more power, better economy, and better emissions. It feels like you are already in the power band right from the start. The ECU also switches to 12 valve mode during cruising. You don't need power when cruising, so decreasing the amount of incoming air allows you to decrease the amount of fuel being burned.
The second stage is 16 valve mode. This is just like a normal non-VTEC motor except that the cam is optimized to work between 2500 and ~ 5000 RPM (as opposed to 0 ~ 5000 on a VTEC motor or 0 - 6800 on a non-VTEC motor. As you know, one cam can't do the job of low RPM and high RPM w/out serious compromises, hence the invention of VTEC.) When switching from 12 valve to 16 valve mode, the feeling is stronger than normal VTEC, but there isn't much of a difference in exhaust sound.
The third stage is your conventional SOHC VTEC mode occurring around 4500 - 5000 RPM. This switches the intake valves to high lift, longer duration, and more overlap resulting in the same peak numbers as the more familiar D16Y8.
The result of the 3 stage VTEC isn't seen at peak hp. But when you compare the dyno graph to a D16Y8, the 3 stage motor stomps it from the beginning all the way to the VTEC crossover, and then matches it from there to redline.
One thing I want to point out is that although 12 valve mode is very similar in operation to the D15Z1 (VX) and D16Y5 (HX) motors, it's not the same. The 3 stage VTEC motor doesn't have roller rockers and it doesn't seem to have been designed for lean-burn mode, at least not to the same extent as the federal (non-CA) VX models. I think in this implementation, Honda was trying to get better performance at low RPM with VTEC-E the same way they were going for better performance at high RPM when they implemented VTEC.
The 3 stage VTEC motor uses a 1-wire O2 sensor. This sensor can detect a stoichiometric 14.7 : 1 AFR or whether the AFR is leaner or richer than stoich, that's it. It doesn't know how much richer or leaner it is from stoich. In order to run at the ragged edge of lean on the federal VX's, Honda used a UEGO O2 sensor. This sensor can detect an accurate AFR anywhere between 10 : 1 and 18 : 1. This is critical when the motor runs fine at 17.1 : 1 but will not burn fuel at 17.2 : 1. I think Honda may have abandoned this extreme lean-burn mode because of what it does for the owner's perception of reliability. You see, any small problem ie a vacuum leak would lead to major problems because it pushes you just over the limit during lean-burn mode. This is how I got my car so cheap. It was bucking like crazy.
*For a pure race car that never sees street duty, a non VTEC motor ie the D16A6 with a high RPM race cam would be my D-series of choice.
Last edited by suspendedHatch on Wed Nov 21, 2007 6:13 pm, edited 1 time in total.
suspendedHatch
Knows Hondas
Knows Hondas
Postby Graham » Wed Nov 21, 2007 5:55 pm
You know im so glad you posted that - im swapping my d15b2 for a d15b next year :thumb:
Graham
Jr. Member
Jr. Member
Postby hondajunkee » Wed Nov 21, 2007 8:25 pm
my d15z1, i didnt paint it and im looking for a new one
hondajunkee
got a BMW but still loves Civic EG's
Postby chasetheskate » Mon Dec 31, 2007 1:12 am
heres mine :hehe:
79 civic hatch w/d16z6 swap with itbs!
95 civic sedan jdm b18c-Turbo
chasetheskate
Noobie
Postby ohDirka » Mon Dec 31, 2007 1:34 am
that is bad ass :woot:
JUICE wrote:Race cars are like boats I guess. Time to bust out another thousand. :x
ohDirka
Admin/Moderator
Admin/Moderator
Postby york62 » Mon Dec 31, 2007 1:46 am
fucking right that sure is bad ass
Craig
Gorveatt wrote:*looks at hand* so what do you want to do baby
york62
Moderator & DIY Master
Postby hatch_wanna_b » Tue Jan 22, 2008 5:42 am
chasetheskate wrote:heres mine :hehe:
Thats hella fucking cool! I love old school hondas rocking newer motors! :D
Heres my D15B.
My good ol' VX valve cover custom painted lol
Bone stock block and head. 98 EX manifold/sorta header lol.
98 EX tranny.
B16A stock intake pipe. AEM filter. kinda ricey. Oh well. lol
hatch_wanna_b
Holdin it down in Southern Illinois
Postby redrum » Wed Feb 13, 2008 4:58 pm
Here a pic of my friend's engine bay gonna post mine soon
redrum
Noobie
Postby ChicagoMike » Wed Feb 13, 2008 5:09 pm
^^I luv your screen name!!^^
------> ALL MOTOR <------
♫ d(-.-)b TRANCE d(-.-)b ♫
ChicagoMike
Admin/Moderator
Admin/Moderator
Postby Apexracing » Wed Feb 13, 2008 6:19 pm
Awsome car bro!!!! :thumb: :woot: :woot:
Apexracing
powered by K series
powered by K series
Postby redrum » Wed Feb 13, 2008 7:23 pm
ChicagoMike wrote:^^I luv your screen name!!^^
Thank you sir :)
redrum
Noobie
Postby DannyCraQ » Wed Feb 13, 2008 9:32 pm
redrum wrote:Image
now thats a nice bay
visit my myspace for awesome hiphop music
http://www.myspace.com/enef
DannyCraQ
EG Groupie
EG Groupie
Postby KRYSTED9354 » Tue Feb 19, 2008 6:01 pm
hondajunkee wrote:my d15z1, i didnt paint it and im looking for a new one
hey i got a perfect running d15z1 vtec-e if u want ??
i am in progress of rebuilding my d16a6 block and d16z6 head and putting them in my vx hope it comes out good, anywase lmk
"If I see it, Then i can, If it changes, Then i will adapt. If i make mistakes, then i will learn."
KRYSTED9354
EG Groupie
EG Groupie
Postby k0rean4life » Thu Mar 06, 2008 7:01 am
I had love for he sohc once... heres my old build
MOTOR:
D16Z6
OEM bearings
balanced bottom-end
ZC pistons with new OEM rings
arp rod-bolts
JG ported and polished head
JG 3-angle valve job
JG valvetrain
Skunk2 intake manifold port matched
B16A throttle body
Injen intake
DC 4-1 header with custom 2.5 collector
Neptune progam
Transmission
S20
Exedy stage 1 clutch
Exedy 11lb Flywheel
....car ripped revved to 8,000 all-day long
INLINEFOUR.COM
If you are in the Southern Ca. area, drop on by and visit our showroom.
11400 Knott Street, Garden Grove, CA 92841.
info@inlinefour.com Or Sales@inlinefour.com
k0rean4life
EG Groupie
EG Groupie
Postby MI_excoupe » Mon Mar 17, 2008 1:45 am
here is mine.. its kinda dirty right now and im thinking about ditching the intake..
R.I.P. Coty "CoCo" Swanson
7-9-91 to 8-16-09
Free Gabe Lorenz!
MI_excoupe
EG Groupie
EG Groupie
PreviousNext
Return to D Series
Who is online
Users browsing this forum: No registered users and 3 guests
