seam sealer
Appearance, Paint & Body Work
seam sealer
Postby mrbojangles13 » Tue Jul 10, 2012 12:33 am
i am in the process of doing a bay overhaul. was wondering what everyone was using for seam sealer? plan was to remove all(as much as i can) the old junky looking seam sealer, prime it n then seam seal it. i would like a sandable option if possible.
do i have the process correct?
any advice would be helpful.
mrbojangles13
Poster
Postby DREAMSPORTS » Tue Jul 10, 2012 2:56 am
You can buy sealer off E-bay, just type in 'Car seam sealer'
Why would you prime it then put the sealer over it? You can paint over most sealers and in my opinon it looks a lot better colour matched, if you're going thru all the time of taking it off why not just get the car seam welded? A lot more rigid :)
DREAMSPORTS
Noobie
Postby mrbojangles13 » Tue Jul 10, 2012 10:33 am
The seams aren't welded for a reason. If u weld em n get into an accident.... I'm sure u can fill in the rest.
To my knowledge you prime first bc if you don't moisture can get in there n rust.
mrbojangles13
Poster
Postby bigpunn421 » Wed Jul 11, 2012 6:43 pm
people fill in the seams all the time for racing. stiffens the chassis.
it might effect it during a collision not 100% on that
1995 4 door civic b18c jrsc
bigpunn421
EG Groupie
EG Groupie
Postby DREAMSPORTS » Thu Jul 12, 2012 5:56 am
mrbojangles13 wrote:The seams aren't welded for a reason. If u weld em n get into an accident.... I'm sure u can fill in the rest.
They aren't welded because its to time consuming and not cost effective..
DREAMSPORTS
Noobie
Return to Exterior & Body
Who is online
Users browsing this forum: No registered users and 1 guest
