Quicky front brake upgrade, brake line question (page 2)
Postby blk92hb » Sat Feb 11, 2012 8:25 pm
ok so now im looking at brake lines do i have to use the ls/gsr front brake lines or can i use my stock brake lines???
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
blk92hb
Jr. Member
Jr. Member
Postby blk92hb » Thu Feb 16, 2012 8:56 pm
bump.
91 s10 (sold)
blk92hb
Jr. Member
Jr. Member
Postby EJ1_MK » Thu Feb 16, 2012 10:42 pm
You can use stock they should be the pretty close to the same, but if you are going from dx spindles to integra ones you might want to get EX or SI brake lines they might be longer for the front since the rotors are an inch bigger.
95 EJ1 BG33P - RC
95 EJ2 BG33P - DRC
Coupe Crew #20
EJ1_MK
Jr. Member
Jr. Member
Postby blk92hb » Fri Feb 17, 2012 3:37 am
ok. so i should be fine because i got a non abs si??
91 s10 (sold)
blk92hb
Jr. Member
Jr. Member
Previous
Return to EG Chassis Brakes
Who is online
Users browsing this forum: No registered users and 0 guests
