- Wed Sep 28, 2011 1:25 pm
#275062
Bought the car stock and starting building right away started mostly with body work; skunk2 springs on kyb struts, skunk2 front and rear camber kits, new ti-rods, and new strut mounts. Then i moved to the motor i swapped another d16z6 into the car and had a custom turbo kit made. As it sits its running about 8psi and i estimate like 175hp. This winter im pulling the motor doin a engine bay tuck and shave, and building my first motor. here is what im thinking:
75mm wisco pistons-
Radiator and hoses
Eagles h beam rods-
acl bearings-
comp cam 59300-
supertech valves springs-
supertech valves (STD)-
Blox retainers-
Supertech bronze valve guides-
machined-
skunk2 intake manifold-
68mm throttle body-
AEM fuel rail-
skunk2 cam gear-
Ram style manifold
Darton Wet sleeves-
Supertech block guard-
Timing belt
Turbo
LSD tranny
Stage 2 or 3 Clutch
Lightweight flywheel
water pump
Oil pump
75mm wisco pistons-
Radiator and hoses
Eagles h beam rods-
acl bearings-
comp cam 59300-
Blox retainers-
machined-
68mm throttle body-
AEM fuel rail-
skunk2 cam gear-
Ram style manifold
Darton Wet sleeves-
Timing belt
Turbo
LSD tranny
Stage 2 or 3 Clutch
water pump
Oil pump
for a boosted D
