DIY: window track repair.
Appearance, Paint & Body Work
Postby 99cx » Thu Apr 29, 2010 6:40 pm
So many Civic owners have trouble with their windows.
the come off the track and then are unable to use them.
So if your window:
-Is off track
-Rattles when you close the door
-wont go up all the way
-or just plain messed up
Follow these steps to repair it. For Good!
Here is the problem to start.
First start by removing your door panel.
Now remove the window. to do so loosen the two screws on each side.
they dont have to come all the way out. enough to slide the track off of it.
once you have taken the window out Remove the 6 10m screws holding the regulator on
Then drop the track through the hole.
Once the track is removed inspect it and look for bends in the metal.
they usually all bend in the same place
(because people get fustrated and yank on the crank going "fukin window wont go up!%$*" and then bend something)
now you have 2 options. bend the metal straight again and pur it back in orrrr re-enforce it so it wont happen again.
since this is the 3rd time its happened im going to fix it for good.
cut metal to fit
place metal
attach metal
annd your done
now install the regulator back in the door.
then put the glass in.
when doing this make sure you lube up the grove in which it slides in
then slide the window all the way down and screw those 2 bolts tight again.
then try it out!
put your door panel back on and your set!
hope this helps some people.
others may not need it.
Enjoy!
:thumb:
99cx
EG Groupie
EG Groupie
Postby chilango41 » Fri Apr 30, 2010 5:19 pm
We did the same thing :thumb:
Nice DIY, use lithium grease on the seal/rail FTW
chilango41
Jr. Member
Jr. Member
Postby 99cx » Fri Apr 30, 2010 5:32 pm
haha awesome! glad to see someone noticed this :P
99cx
EG Groupie
EG Groupie
Postby Ajax1989 » Fri Apr 30, 2010 11:02 pm
nice DIY, instead of reforein mine i just went to the junk yard and got one for 20 bucks!! :thumb:
Ajax1989
Nissan Primera
Nissan Primera
Postby Gorveatt » Fri Apr 30, 2010 11:12 pm
Added to the DIY thread list :thumb:
Remember when Civics were cool ? Yea me neither
Gorveatt
H.I.D. Master
H.I.D. Master
Postby 99cx » Fri Apr 30, 2010 11:26 pm
Yayy! :thumb: :P
99cx
EG Groupie
EG Groupie
Postby Boods » Thu May 13, 2010 7:50 pm
Just wanna say a big thanks mate! this really helped me when my window came out of the rubber sleeve bit and wouldn't go up to the top.
If it wasn't for you i'd have ended up taking it to get done at a shop!
Thanks man <3
Boods
EG Groupie
EG Groupie
Postby 99cx » Thu May 13, 2010 7:54 pm
awesome! Glad i could help! :thumb:
99cx
EG Groupie
EG Groupie
Postby waynlewis » Sun Aug 29, 2010 1:41 pm
Thank you sir, gonna try this out on my passenger window. Might even get one from the jy, reinforce and install it. :thumb:
waynlewis
Poster
Postby 99cx » Sun Aug 29, 2010 1:45 pm
Right on man, Good luck!
99cx
EG Groupie
EG Groupie
Postby jayEGR » Mon Aug 30, 2010 1:48 am
thats sweet man like what you did with that always more DIY is great to do have it in handy iam do this to lub up my tracks good pic :thumb: :thumb: :thumb:
*my builds* gotta love a nasty ass coupe with a good forum on your back
http://civic-eg.com/viewtopic.php?t=17925
http://civic-eg.com/viewtopic.php?t=16920
#2 COUPE CREW MEMBER
jayEGR
Jr. Member
Jr. Member
Postby K20z3EgHatch » Tue Oct 05, 2010 12:14 am
Nice diy. Mines out because the rubber on the trac thing is ripped
K20z3EgHatch
Poster
Postby orangeEG » Mon Apr 11, 2011 1:55 am
Tiring this tomorrow morning, my window went right before putting it away for winter and now that it's out again for summer, the wifey doesn't like that I can't do drive-thrus, this will make her happy : )
orangeEG
EG Regular
Postby dbrooks » Mon Apr 11, 2011 6:58 pm
good write up!
dbrooks
railroadin'
railroadin'
Postby HatchbackCrusader » Thu Apr 14, 2011 1:04 am
Good DIY, I did everything and still heard an annoying rattle. Turns out it was the damn antenna. :lol:
HatchbackCrusader
Poster
Next
Return to Exterior & Body
Who is online
Users browsing this forum: No registered users and 1 guest
cron
