- Mon Apr 11, 2016 7:06 pm
#358874
That is the best plan of attack. You are on the right path. Give us the update of good news when you can.
EconoBox wrote:It's going on the alignment rack any minute now.
We loosened the steering rack, motor mount bolts, and steering rack. We are going to shift the subframe to even out the caster in case it moved. From the alignment rack readings we should be able to see if there is anymore damage. The readings should give me an idea what/if anything else is damaged. Worst case scenario I just have to drive across the street to our collision building and put it on the frame rack to measure the subframe.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
