Post YOUR Sedan here
By Loaf31
#355267 I filled up the tank with gas about 4 days ago and when I opened the cap, it hissed, so I think it's holding pressure.
I'll check the vacuum lines :thumb: thanks!
By Loaf31
#355278 Well, checked the timing and it's off by a good margin. I tensioned the belt properly the other day I believe.
When tensioning, you crank the cam sprocket clockwise to tension it, right? :eh:
By Mr Rattles
#355290 Ride of the month whoop whoop.
Congrats bro
By Loaf31
#355295
Mr Rattles wrote:Ride of the month whoop whoop.
Congrats bro
Thanks man :thumb:
My first time as ROTM! And hopefully not the last :wink:
By Mr Rattles
#355299 hehehe, i must still work my way up and try earn that title.
1 day when im big :D
By Loaf31
#355324
Mr Rattles wrote:hehehe, i must still work my way up and try earn that title.
You got this, bro! :D
By Loaf31
#355341 Bump, someone help with my timing issues?
By Loaf31
#355435 So, I checked the Mechanical timing and everything is spot-on. The ignition timing was off, so we put the car in diagnostics mode and Rotated the distributor until the 3 marks on the crankshaft pulley lined up with the plastic marker on the timing belt cover. The car idled very well and only stumbled a bit upon revving. Then, we reset the ECU and let it idle for 10 minutes. Then, when I gave it a rev, it stumbled a LOT. When we took it for a short test drive (the car was at operating temperature), it accelerated perfectly when only at 15-25% throttle. Any more than that, and it stumbled very badly and would not accelerate barely at all. This is starting to make me assume that it could be the Throttle Position Sensor? Keep in mind that the CEL isn't on and its not throwing a code. Somebody help me out? :?
By Loaf31
#355476 Just glad I can move forward with this build :thumb:
Future Mods:
Yellow Fogs
Red/Clear Tail Lights
Also picking up some mystery items on Saturday! So excited :twisted: :hehe: :D
