Milano Red EG8 - new ideas, and a new direction for the car
Post YOUR Sedan here
Postby juls1488 » Mon Oct 14, 2013 6:52 am
TrailerTrash wrote:cant wait!
when yuo putting the blower on!
unfortunately not til February-ish.
i still need to get a couple of things, and i wanna make sure that the zc is running flawlessly before boosting it.
i broke my valvecover ground strap and then got called into work at a stupid time, so i didn't get anything done today.
hopefully ill have time to finish up tomorrow morning, but if not definitely on tuesday
juls1488
EG Groupie
EG Groupie
Postby brandoff88 » Mon Oct 14, 2013 4:04 pm
looking forward to seeing this beast run! good luck with build man
brandoff88
That one guy with the hair
Postby juls1488 » Fri Oct 25, 2013 3:09 am
sorry bout the lack of updates. been hunting down a coolant leak. and i found it.
the plate where the hoses connect to on the IACV was a little bent. just enough to make it spray coolant. drove me nuts for two days. musta bumped it against the firewall or something dropping it in, cause that wasn't like that when i unpacked it. but once i found it i removed the IACV, undid the three screws holding the plate on and used a bench vise and just a very little bit of hammer and tapped it as flat as i could. a touch of gasket maker on that corner, and it holds good as new. :thumb:
she runs like a champ.
more pics tomorrow of the motor in.
juls1488
EG Groupie
EG Groupie
Postby TrailerTrash » Fri Oct 25, 2013 12:36 pm
:thumb: :thumb: :thumb:
TrailerTrash
Sr. Member
Sr. Member
Postby juls1488 » Sun Oct 27, 2013 12:31 pm
pictures!!
not the real decal that goes on the da1, im saving those for after paint. 8)
:thumb:
juls1488
EG Groupie
EG Groupie
Postby juls1488 » Mon Oct 28, 2013 4:52 am
going oem big brakes!
picked up some rebuilt crv calipers with 25t brackets, and some 96 prelude vtec 11.1" rotors and pads.
not sure when im going to install them, but ill post pics when i do!
:thumb:
juls1488
EG Groupie
EG Groupie
Postby juls1488 » Mon Nov 04, 2013 5:35 am
figured id post an updated mod list since a bunch of stuff has changed.
updated mod list, current as of 11/2/13:
Suspension/brakes:
-96-spec Type R 4x114.3 conversion
-Prelude non vtec front calipers and rotors
-94 Accord rear rotors with RSX base models calipers
-91 Civic EX 15/16th brake master cylinder
-Integra RS 4040 proportioning valve
-Full poly bushing
-Functtion7 rear LCAs
-flat black ASR subframe brace
-25mm rear OBX sway bar with prothane bushings and blox spherical links
-extended front studs
-Koni yellow struts
-Ground Control coilovers 340f/250r with extended top mounts
Engine/trans/exhaust:
-dohc zc
-avid mounts
-aem short ram
-yonaka stage 1 clutch
-95 si tranny
-rebuilt stock linkage
-energy suspension poly shift bushing
-stock shifter
-yonaka exhaust
-obx 4-1 big tube header
-2.5in test pipe
Interior:
-pioneer speakers all around with a jvc headunit
-pw:jdm shift boot and delrin knob
-96 prelude seats
Exterior:
-denji black housing headlights
-depo foglights
-oem spoilerless trunk
-mugen lip
Wheels:
-1996 Integra Type R 15x6 +50 on 195/50/15
-nissan 200sx widened steelies 14x7 +0 on 185/60/14
-AHI Mesh 14x7.5 -3/-6 on 155/55/14
in the works is an oem big brake upgrade. crv calipers and brackets with 96 prelude vtec 11.1" rotors. gonna have to say good bye to the 14s. :(
also have some other goodies, like s2k cmc with braided line, ss brake lines, and a jrsc.
thanks for looking! :thumb: :thumb: :thumb:
juls1488
EG Groupie
EG Groupie
Postby silverEG8 » Tue Nov 05, 2013 6:33 am
Good work
1995 DX Sedan - my really slow project... and definitely lovin' it.
silverEG8
EG Regular
Postby MistahJuice » Tue Nov 05, 2013 7:43 pm
Very nice. Crazy how the bracket got bent like that.
MistahJuice
Poster
Postby TrailerTrash » Tue Nov 05, 2013 9:20 pm
what you doing with those 14s!?!?!?!?!
TrailerTrash
Sr. Member
Sr. Member
Postby juls1488 » Tue Nov 05, 2013 10:23 pm
TrailerTrash wrote:what you doing with those 14s!?!?!?!?!
I'm probably gonna sell em. They're 4x114 though, so its gonna be a little tough to sell around me.
@junmadrid - thanks man
@MistahJuice - thanks, yeah I don't really know how that for bent, but it just big enough to spray coolant all over the bay while driving, but wouldn't drip while idleing.
Gonna try and do the brake swap this weekend. Stay tuned.
:thumb:
juls1488
EG Groupie
EG Groupie
Postby TrailerTrash » Wed Nov 06, 2013 4:04 am
gosh darnit i forgot they are 4x114 :x :x :x
TrailerTrash
Sr. Member
Sr. Member
Postby juls1488 » Thu Nov 07, 2013 10:57 pm
TrailerTrash wrote:gosh darnit i forgot they are 4x114 :x :x :x
yeah, not alot of people with that pattern around here. have to find someone with a 240 or an old corolla.
picked up my 11in 'lude rotors and pads, gonna put those on with the crv calipers tomorrow. pics when im done.
also having some non-motor related electric issues. my tach needle bounces when i use the turn signals. :?
hopefully i can get that sorted out tomorrow too.
juls1488
EG Groupie
EG Groupie
Postby juls1488 » Fri Nov 08, 2013 4:33 pm
what started as a small problem, tach bouncing when signalling, has turned into a full-blown total electrics failure.
wtf :x
i know my alt was having issues, was whining really bad and loudly, and my battery was on its last legs. gonna switch those two out, check grounds and fuses. hopefully thatll take care of it. if not, ill be starting another thread lol.
wish me luck!
juls1488
EG Groupie
EG Groupie
Postby MistahJuice » Fri Nov 08, 2013 7:00 pm
Damn that blows, at least you've got some known issues to start with. I should probably replace my battery soon too. Whenever I try to use anything with the car off lights get super dim and the speakers sound like theyre blown lol
MistahJuice
Poster
PreviousNext
Return to Your Ride - Sedan
Who is online
Users browsing this forum: No registered users and 1 guest
