By 1-low-92-EG-Sedan - Thu Aug 04, 2011 5:24 am
#266196
Mods list
Interior:
-wink mirror
-NRG short hub
-NRG quick release (version 2.0 black/titanium/red)
-NRG steering wheel with flat bottom (black suede/leather)
-Type R style shift boot (black suede with blue stitch)
-BWR weighted shift knob .97 Lbs (440g)
-DelSol seats (blue/grey)
-three gauge pod pillar (grey to match interior)
-Glow Shift 7 color tinted series gauges (oil pressure, water temp., volts, and wide band air/fuel ratio)
-Kenwood deck KDC-BT555U
-Kenwood speakers front/rear powered by Kicker 4 channel speaker amp
-12" Kenwood sub (400 RMS) powered by a Planet Audio amp (450 RMS)
-black/Grey Bride door insert panels
-B&M daul bend short shifter (silver)
-LED cluster (blue)
-LED climate control/dash buttons (white)
-EDM center (grey to match interior)
Exterior:
-Mugen style front lip
-yellow fogs
-HID kit 3,000k
-black housing headlights
-HID kit 5,000k
-smoked amber corners
-smoked amber side markers
-tinted windows/windshield strip
-rain guards (slim style)
-EK 4door side skirts
-EG mud guards
-spoon style mirrors
-50/50 taillights
-antenna block off plate
Suspension/Wheels/Brakes
-Tein coilovers
-BWR rear LCA's (polished)
-Front upper control arms with Camber adjustment
-ASR Subframe brace (polished)
-ASR 24mm sway bar (Grey)
-ASR end links
-Energy Suspension poly bushing kit (full car) (red)
-DNA Motoring front/rear upper strut bars (Red/Blue)
-Front cross drilled and slotted brakes
-Rear disc conversion with cross drilled and slotted brakes
-Wheels - Traklite Crosstread (White/polished Lip) 15x8 15 offset with 195/45/15 Nexen N3000 tires
-about 20 inches from ground to wheel well
Motor/Transmission:
-D16Z6
-head was milled and valves where newly seated and has new seals
-brand new crank with matching bearings
-OEM oil pump from Honda
-OEM water pump from Honda
-OEM timing belt from Honda
-Hastings piston rings (std. bore)
-honed out cylinders
-new oil pan
-ARP head studs
-ALL the seals and gaskets in the lower end (head gasket, rear main seal, oil pan gasket etc. etc.)
-NGK spark plugs and wires
-short ream intake with K&N filter
-Y8 intake manifold
-stage 3 XTD 6 puck sprung clutch
-P28 chipped ecu
-Spec-D tuning 4-2-1 header
-2.5" custom exhaust
-N1 style muffler
-dual core all aluminum radiator
-Walbro 255 Fuel pump
Interior:
-wink mirror
-NRG short hub
-LED cluster (blue)
Exterior:
-yellow fogs
-HID kit 3,000k
-HID kit 5,000k
-EG mud guards
-50/50 taillights
-Tein coilovers
-ASR end links
Motor/Transmission:
-D16Z6
-new oil pan
-ARP head studs
-Y8 intake manifold
-P28 chipped ecu
-N1 style muffler
Last edited by 1-low-92-EG-Sedan on Sun Jan 04, 2015 6:49 am, edited 32 times in total.
