- Wed Jun 06, 2012 6:03 am
#307482
Nice to see a fellow EE in here
IMO S2k Cluster swap is pricey. first of all you have a cluster that runs for 150-200 (AP1 is cheaper than AP2) then you have to buy Speedohealer and the water temp box. and if you are not good with wiring - then a wire harness.
it will run you close to 300-450 depending on deals and prices.
it looks dope though
mitch6 wrote:LionHearted1 wrote:there is tons of things you can do lol
I have wired up DC2, EK, and S2K clusters into eg's, changed out the seats, My car has an ek center console conversion, DC spindle and brake conversions (4 wheel disk) etc...
If you want pics check out my build, and the DIY secion has tons of info
There certainly is!
I love the S2K cluster in your EG6. Was it hard to do?
the research was the tricky part seeing as most, if not all DIY's are incomplete...some of the wiring posted on the DIY's were no good, so I had to refer to some more accurate findings
If anyone needs some info or sites for information on the S2K cluster swap, pm me
Once all the research was done, took me about 6 hours to install and have it programmed and on the road, had to redo the wiring because the first time had a few mix ups... lots of wires!!! I am actually a 4th year electrical engineering student, not saying that ahs anything to do with this swap, but it does show I enjoy electrical work
