Page 1 of 4
Painting a D-series valve cover
PostPosted: Fri Oct 24, 2008 4:20 pm
A D-series civic looks a lot better under the hood with a nice valve cover.
Here's what you need from left to right:
Wax & Grease remover
Self Etching Primer (great for bare metal)
Engine Enamel Black
Engine Enamel Clear
and sand paper, file, wire brush, tape (not pictured)
All the above, plus some elbow grease is going to help create this:
from this:
Here we have an old dirty corroded valve cover.
Look close at all the casting marks. Your paint isn't going to look smooth at all if you just paint over these.
Here is another pic after smoothing them.
You can use files to get the worst of the larger marks, then some low grit sand paper (180 or 240 is good) to finish them smooth.
To get all the corrosion off of the surface (a problem if you like in areas that use road salt), I used a sanding wheel. The wire brush is also good in tight areas but if it if too stiff it can add deep scratches to the surface so watch out.
After the whole valve cover is smoothed & sanded and there is no corrosion left, it is time to give it a good cleaning with wax & grease remover.
After you've cleaned it, mask off the areas you don't want painted.
Next apply light coats of the Self Etching Primer. The pic was taken after several light coats. Several light coats is the way to do it, not one heavy coat that will take forever to dry and possibly run.
After the primer is dry, you can block sand the surface of the letters. I forgot to get a pic of this step. You could wait and block sand after you paint your color as well.
Applying light coats of color. Be sure to use a paint that can withstand the temperatures. Even if your light coats look splotchy, it is better than going on too thick and having it run. Light coats may take longer and look dull or splotchy, but the end result is what matters.
I've got a few light coats applied.
For the final color coat, do a "wet coat" which is a little heavier than your light coats. This will help to fill in any overspray areas or blotchy areas for a smooth finish. But not too thick or it could run. If it runs, wait until it dries, wet sand the run smooth, and then do another coat of color. I'm using an enamel paint which takes something like 7 days to cure before you can re-apply more coats. So a run will really slow down your progress. :thumbdown:
After the color coat has dried, you can block sand the letters carefully. Use a somewhat low grit to get through the paint (320) then work your way up (400, 600, 800, etc) on the bare metal surface of the letters. The higher grit you go up to, the less visible your sanding marks will be.
Then Lay down the clear just as you did the color, except you can do more coats. This way if you end up with orange peel, you will have more clear to wetsand to get a mirror smooth finish.
The results:
notice the tiny pinholes. It could have been in the casting, or I may have held the can too close when I was spraying.
The area in this inner lip is hard to get with the paint. It's a little rough looking because applying the wet coat here could have resulted in a run on the more visible areas around it.
PostPosted: Fri Oct 24, 2008 6:02 pm
by egsedanguy
i like that. i did mine at night in like 20 min. its hella easy. ill put up some pics of mine
PostPosted: Fri Oct 24, 2008 6:52 pm
by Civic_HatchSI
sweet write up Brian :thumb:
PostPosted: Fri Oct 24, 2008 6:55 pm
by Graham
Nice write up :thumb:
The pinholes can be due to moisture in the paint - since you didnt use a booth then that can be quite likely!!! Ive had them a few times on various things ive painted, you can sometimes wet sand them out but they're not that noticeable unless you're up close
PostPosted: Sat Oct 25, 2008 3:39 am
by 0p71mu5pr1m3
I've been wanting to do this for a long time, but doing like a red urban camouflage.
PostPosted: Sat Oct 25, 2008 6:56 am
by khmer_gentleman
that looks awesome. i cant wait to do it. too bad i cant do it this weekend since i only got off sunday, and i gotta spend that day with the gf
PostPosted: Sat Oct 25, 2008 10:20 am
by biretsu89
wow that came out nice :thumb: .... mine looks all jacked up... I have nice paint.. but some how my valve cover is bent at one point O.o :roll:
PostPosted: Sat Oct 25, 2008 2:20 pm
by Gorveatt
Sweet Brian looks great :thumb:
PostPosted: Sat Oct 25, 2008 2:26 pm
by KRYSTED9354
:thumb: LOOKS AWESOME :thumb:
PostPosted: Sat Oct 25, 2008 9:15 pm
by dogfight
damn those came out smooth teal.
i tried doing mine haha it ended up looking like bird poo
PostPosted: Sat Oct 25, 2008 11:41 pm
by Sentry
Mine looks pretty rad. I was trying to replicate the factory paintjob. :wink:
PostPosted: Fri Jan 02, 2009 9:59 pm
by EgCruiser
a picture of the engine in the engine room please
PostPosted: Fri Jan 02, 2009 10:07 pm
by smokinsoljah420
:thumb: looks great but how did you fight yourself not to just keep it like this?
That looks sick! :thumb:
PostPosted: Fri Jan 02, 2009 10:44 pm
by Sentry
I used textured paint on mine for a factory look since I knew I would struggle trying to get a smooth finish with a rattlecan. :lol:
PostPosted: Thu Jan 08, 2009 1:46 pm
by stockd15
Valve cover came out nice :thumb: Do you think regular rustoleum paint will hold up to the temp on the valve cover?
