DIY: Antenna Block-Off Install
Appearance, Paint & Body Work
Postby Loaf31 » Tue Oct 06, 2015 6:55 pm
My radio doesn't work, and the antenna looked so bulky and out of place. but, I plan on fixing my radio and still need the antenna, so I wont remove the whole thing.
This DIY will show you how to block off the antenna part, but still have access to it later.
Should only take 15 minutes at the most.
First, remove the old antenna plate. Unscrew the 2 screws and place them somewhere you wont lose them.
You will see that the silver piece is attached to one of the holes. Just pry it off with a screwdriver.
I believe this is the ground plate, so it might be a good idea to wrap it with electrical tape.
Slide the old antenna cover off. Keep the rubber part, you'll need it.
Old vs. New
Bend the silver piece back and slide the whole thing back into the hole.
Swap over the rubber part that you saved earlier
Re-install, and you're done!
93 EG8 D15B7
My Build Thread:
viewtopic.php?f=61&t=28131
Instagram: @Stance_God
Loaf31
Jr. Member
Jr. Member
Re: DIY: Antenna Block-Off Install
Postby teal_dx » Wed Oct 07, 2015 4:13 am
Thanks for taking the time to create another good DIY :D
Added to the DIY List:
viewtopic.php?f=38&t=1474 :thumb:
Do Not PM me your technical questions. Post them in the forum! :thumb:
teal_dx
The Legend
The Legend
Postby Loaf31 » Wed Oct 07, 2015 7:48 am
:thumb:
93 EG8 D15B7
My Build Thread:
Loaf31
Jr. Member
Jr. Member
Postby Driv-it-hard » Wed Oct 07, 2015 2:06 pm
Looks great !!!!
I shaved mine.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
Driv-it-hard
EG Groupie
EG Groupie
Postby suspendedHatch » Sat Oct 17, 2015 7:03 pm
Thanks for using "lose" correctly instead of "loose". I wince every time people get that wrong in a DIY. It's more common that you might think.
My antenna mast was fuckered so I yanked it out. I'm going to have the hole shaved but I have the blank on there for the time being. I don't listen to the radio in my Civic, but in my Accord I installed an interior antenna on the windshield tucked out of view. Reception is the same if not better than the original antenna.
suspendedHatch
Knows Hondas
Knows Hondas
Return to Exterior & Body
Who is online
Users browsing this forum: No registered users and 2 guests
