- Wed Dec 18, 2013 11:31 pm
#340292
I just finished with the projector retrofit and wired up the ballast. went to power up the lights only the left projector works but not the right projector. I figured it was a bad ground so I moved it the the battery ground. still didn't light up. all the connections are fine. I don't have a clue what else to do next exept to take a voltmeter to the power wire of the ballast to see if theres power.
anybody have a list of possible things to be wrong?
ok just tested the voltage on a cheapy volt meter. the 12 v light came up on both power wires that plugs into the morimoto ballast. so does this sound like its the ballast or the bulb that's having the issue?
I know one thing tho, I can hear a humming noise coming from the ballast WITH the working projector. any ideas?
