- Tue Oct 15, 2013 9:59 pm
#337734
I want to repaint my OEM spoiler. I have it off the car and found rust on the metal portion under the plastic shell. How do I separate the black plastic piece from the metal piece?
- Fri Oct 18, 2013 4:12 pm
#337801
Anyone
- Wed Apr 16, 2014 2:41 am
#344641
I just picked one up today. If you even still need to check this...
I would be hard pressed to see it separate easily. There looks to just be a few screws and plastic clips holding it all together, but there is also an adhesive on there from the factory holding it all together.
You MIGHT be able to heat it up with a heat gun, but you probably risk warping it instead of removing it.
White CDM EG6 5-speed
Carbon fiber hood, lightweight carpet, rear interior gutted, faux suede headliner and a-pillars. Nothing power, no radio or A/C and no center console.
Just me, my B16a2, K-Tuned short shifter and the road.
- Wed Apr 16, 2014 3:23 am
#344644
no problem. I was actually looking for information on painting the plastic...
kind of want my junkyard find to be all white to match the car, but there is the plastic texture crap... which would either involve THIN bondo or HEAVY primer filler... black it will stay i guess.
- Thu Apr 17, 2014 1:35 am
#344669
I guess I will give it a go, need to get a new rattle can to finish the roof molding and do the spoiler, so I will have enough.
I have high grit than that, so we will see how it goes. The pepboys by me had barrett jackson sand paper on clearance, picked up a BUNCH of packages of sand paper and scotch pads for 1.90 a pop. Hell of a deal, have full supply of 80, 220, 400, 600, 1000, 1200, fine scotch and very fine scotch.
also in the process of refinishing and painting the rims that came with the car, going graphite with matte clear, and white spoiler.
- Sun Apr 20, 2014 10:08 am
#344792
The plastic sections do come off, you take the snall side parts off first then the middle bit. There's terrible clips inside that are white and will 100% break but between sliding it back in place and the obvious screws/ clips and even a small bit of sealer you can reattach it securely. Just make sure the remains of the clips are out the spoiler when they break or they rattle around!
