it turns out that 2 were 2k epoxy primer and two were 2k urthane acrylic filler...
so i sprayed my bare metal and bondo areas with the primer and then i sprayed another layer using the filler
...is it ok to spray filler over the primer??!
nd1983 wrote:yes its ok, but not recommended as the filler won't smooth out like the primer will. you could end up doing a lot of sanding to get it perfectly smooth
nd1983 wrote:800 and a good orbital sander would make it quicker but will take still be a bunch of sanding
Users browsing this forum: No registered users and 1 guest
