- Sat Nov 29, 2008 4:26 pm
#80846
As most of you guys have seen in my other posts, I have added a set of ls mesh rims on kuhmo ecsta ast 195-50r-15. My question is this, after lowering my car and adding the new rims and tires I had gotten a wheel alignment. Was that a waste of 50 bucks since I dont have a camber kit? I went through a set of front tires because they messed up my alignment and I only had the front tires for less than 2 months. After replacing those tires yesterday i took it to another place to get a wheel alignment and he told me i needed a camber kit and other stuff as well. Is this true? what all would i need in order to not wear my tires down. I dont do burnouts or junk so thats not why they wore out. thanks for the info to come..
- Sat Nov 29, 2008 4:29 pm
#80848
My coupe's lowered and on 15's. I wouldn't bother with a camber kit unless you DUMP the thing. A little bit of camber doesn't hurt very much, and as other people who know 100% what they're talking about will tell you, it can actually help in some situations.
The alignment is good, it'll reduce your tire wear and prolong tire life, you're fine now how you are.
