proper front strut bar installation
i have this "jdm spec" front strut bar installed in my eg. it is the type with the crescent-shaped ends.
it is installed with the crescent pointing towards the back. i've seem some pictures in the net that shows the same bars but the crescent facing front. does this make a difference? i mean these two positions result in the bar being 3-4 inches either front or backwards. any handling differences perhaps?
also, if i have to change it, does the surface have to be flat so as not to adapt whatever irregular angle my struts are at the time i would change them? or i can just change it and they will adjust on their own?
thanks
thanks
