- Sun Aug 31, 2008 9:08 pm
#67864
I'm not exactly sure how low I was when I was running the weds. I'm still the same height on the car now that the si's are on but I just adjusted the camber so now the camber is sitting at about 2 degrees in the rear and the front is 0 I think. I still have a bit of rubbing issues in the rear but not much. Probably would help if I updated shocks
haha..anyway here's a picture of how much I had to camber my weds to get them to fit under the wheel wells and be "slammed"
This is a side shot of it somewhat "slammed"
as you can tell it doesn't look like I'm cambered in the rear but by the first picture you can tell how much I had to camber that thing to get the tires to fit.
With the si's on my car I can slam it some more but I'd probably wanna go with a smaller tire..I'm running 195 50's on the si's and they rub in the back when I hit bumps..the front is no problem.
Greasedmonkey wrote:Jdm_Katie wrote:yeah exactly what he said..just gotta get a camber kit front and rear is like $250..and then just adjust the back to however much camber you wanna run. then it will look like the hatch in the pictures above..I am currently 2 degrees of negative camber in the rear..when I had my other rims on I was probably like 5 or 6 lol maybe more.
you are a brace girl!! how low are you an what does that look like on your coupe? Ive never had to add camber to be hella low. When i put my ksports on my other hatch, i had them all the way down and still didnt rub anywhere.
[/img]
