- Mon May 05, 2008 4:43 pm
#53884
Only adding the rear to site. Front camber is covered
haha
This is super easy. Takes longer to jack the car up and take the wheel off than to install. Just in case someone is curious =]
Parts going in
After the car is jacked up, put another jack on the outer end of the rca. This will allow you to remove the center bolt from the arm without it binding against the bushing.
Remove the three bolts and remove the arm.
Stock Vs. aftermarket
Reverse the removal steps and your golden
I replaced the two bolts the go into the wheel well with a higher grade bolt.
hahaThis is super easy. Takes longer to jack the car up and take the wheel off than to install. Just in case someone is curious =]
Parts going in
