Sun Sep 07, 2008 3:42 pm
				by defjamon26z
				you install the ground wire on the value cover. that really isnt gonna help anything at all. dont you know you got a gasket between the valve cover and the motor? hahahaha
have that wire install to the metal on the power steering pump.
Wed Oct 15, 2008 5:08 pm
				by mooze
				i wanted to build a floor but my box is to big. nice install
Wed Oct 15, 2008 6:15 pm
				by tigerafro
				whats the rockford thing for ?
Wed Oct 15, 2008 7:25 pm
				defjamon26z wrote:you install the ground wire on the value cover. that really isnt gonna help anything at all. dont you know you got a gasket between the valve cover and the motor? hahahaha
The wire goes to the bolt which goes direcly to the Head = good ground
It's above the rubber insulator so it is not even touching the valve cover.
Wed Oct 15, 2008 7:36 pm
				by sdots
				Nice install man, not too keen on the door speaker covers though, would of left them as they are.
Sun Oct 19, 2008 12:02 am
				by Macster
				The trunk layout is hella sick i will have to do that to mine i dont have a spare tire cover as is.
Fri Oct 31, 2008 4:05 pm
				by mooze
				tigerafro wrote:whats the rockford thing for ?
its a fuse
Fri Dec 26, 2008 5:37 am
				I love the false floor in the trunk
Fri Dec 26, 2008 6:59 am
				by trustdestruction
i hope you're not serious...
The ring terminal is between the metal grommet washer and the nut.  The nut is screwed onto a valve cover stud and it bolted into the head.
It wouldn't come bolted that way from the factory (which it does) if it didn't work.
Mon Dec 29, 2008 5:24 pm
				by xswingkidx
				trunk setup looks great!
Mon Dec 29, 2008 10:43 pm
				by BLACKS' COUPE
				i got a quick question as in regards on your pattern. Can you help me get a clean pattern by giving me your secret on yours? what did you use to cut the wood to specs? any tracing?
Mon Dec 29, 2008 10:58 pm
				by sqsi
				BLACKS' COUPE wrote:i got a quick question as in regards on your pattern. Can you help me get a clean pattern by giving me your secret on yours? what did you use to cut the wood to specs? any tracing?
For my hatch I took out the carpet and traced it onto the wood, not sure if that how this one was done.
Mon Dec 29, 2008 10:59 pm
				by sqsi
				Nice choice in equipment, gotta love sound quality
Mon Dec 29, 2008 11:00 pm
				by BLACKS' COUPE
				thats what i had planned but i'm missing my trunk carpet due to last owner taking it out and decided to leave it naked..
Tue Dec 30, 2008 12:09 am
				by sqsi
				bummer
