- Sat Nov 14, 2009 1:05 am
#156496
Well i spent a better half of two days working on this since i got fed up with there being either auto harnesses or 92 civic harnesses (where the map is on the firewall and the wiring is in the chasis harness...) at my local junk yard and all the 5spd harnesses i needed where cut by idiots.....
Mainly did this so as to use a d series harness on a integra motor and i thought whilst i was working on figureing whats what i decided to go ahead and figure out everything just in case........and since i couldnt find the engine harness diagram in the repair manual i decided to do it myself
(Caution: I bare no responsibility for you screwing up its your fault not mine the harness i used was from a 92 civic 5spd so others may be different but so far i havent found any differentiation besides vtec and of coarse auto......so lets begin shall we)
Wires and plugs are not in order in any way i just did as i pleased lol....
And when i say the wires and their approx position im looking at the female end and the clip side up
And when color/ color comes up that means main color/stripe color
Map Sensor
3 wires spaced left to right
White-Green-Yellow/green
TPS sensor
Yellow/White-Red/Blue-Green/White
IACV sensor
2 wires spaced top bottom
Blue/yellow-yellow/black
VSS sensor(speed sensor)
Yellow/White-Yellow/blue-Black
Fan switch/engine temp sensor
Black-Green
Thermostat Ground
4 wires connecting into one looped connector
-2 black wires-Red/black- Brown/black
Distributor Plug 1(large plug)
7 wires 1 blank distributed evenly from left to right (from upper left if looking at the plug eonnector side with clip up....)
1-Orange
2-Orange/blue
3-Blue/green
4-Yellow/green
5-White
6-White/blue
7-Blue/yellow
8-blank
Distributor plug 2 (small plug)
2 wires left to right
Black/yellow-Blue
02 Sensor plug
4 wires distributed evenly left to right top to bottom(from upper left)
1-Green/white
2-White
3-Orange/black
4-Yellow/black
Reverse sensor
Yellow-Green/black
(unsure of sensors name)
1 wire going to the head near the trans....
Yellow/green
(unsure of sensor name)
2 wires from top to bottom (this goes to the other sensor on the head....)
Red/white-Green/white
Starter wire
1wire female clip
Black/white
Now im going to reverse from where i started working my way to the other side....
Oil temp/psi sensor
1 wire
Yellow/red
Air intake temp sensor
Green/white-Red/yellow
Vaccum sensor plug
Yellow/black-Red
Alternator to fuse box wire
1 wire
White
Alternator plug
4 wires distributed evenly top bottom left to right (1 and 2 are horizontal, and 3 and 4 are verticle)
1-Blue
2-White
3-Black/yellow
4-White/blue
Fuel injector plugs
8 wires 2 in each plug from left to right with clip side up. a being left b being right....and im going from the farthest away from the harness itself first to the one closest....
1a)Yellow/black
1b)Yellow
2a)Yellow/black
2b)Blue
3a)Yellow/black
3b)Red
4a)Yellow/black
4b)Brown
End of the 1992 Engine plugs
Now i also had at my disposal a 94 si harness from a 5spd so here we go
Vtec solinoid
2 plugs
1wire plug
Green/yellow
2 Wire plug
Blue/black
Black
and at the junkyard i just glanced at the only plug needed for the auto trans (that two tier thing that looks like a dual vtec solinoid oil pressure sensor......
2 wire plug
Green/black
and either Yellow or Yellow/white
Now look onto the next post I made to see the strut tower harness plug breakdown
Map Sensor
TPS sensor
IACV sensor
Black-Green
Thermostat Ground
1-Orange
2-Orange/blue
3-Blue/green
4-Yellow/green
5-White
6-White/blue
7-Blue/yellow
8-blank
Black/yellow-Blue
02 Sensor plug
1-Green/white
2-White
3-Orange/black
4-Yellow/black
Reverse sensor
Yellow-Green/black
Yellow/green
Starter wire
1wire female clip
Black/white
Oil temp/psi sensor
1 wire
Yellow/red
Vaccum sensor plug
Yellow/black-Red
1 wire
White
Alternator plug
1-Blue
2-White
3-Black/yellow
4-White/blue
Fuel injector plugs
1a)Yellow/black
1b)Yellow
2a)Yellow/black
2b)Blue
3a)Yellow/black
3b)Red
4a)Yellow/black
4b)Brown
Vtec solinoid
2 plugs
1wire plug
Green/yellow
2 Wire plug
Blue/black
Black
2 wire plug
Green/black
1980 volvo 242
2001 crv
2001 crv
....wow thats awsome nice job man. could someone please make this a sticky ..
